quick swap question
quick swap question
if a b16 comes out of an EG6 in japan... ( sirII or whatever it would be) can you use those oem mounts to install the motor into a USDM eg hatch?... ive always been under the impression that you couldnt and you have to resort to the integra drivers side/tranny mount setup.. or aftermarket
whats the low down?
thanks!
whats the low down?
thanks!
Re: quick swap question (claytonsmith)
uhhh let me see...iam not that sure...but i think u could use...sum but not all...cuz the car u gettin the motor 4rm is a RIGht hand DRIVE RIGHT..:??
Re: quick swap question (K20CIVIC007)
yeah but that doesnt affect how the engine sits....the brake and clutch master cyl are on a dif side... the wiring harness is longer. other than that.... the mounts shouldnt make a dif
Re: (ekb16)
ahh ok i was under the impression that you couldnt.. .. i believe that IS the case with a cable b16 (obd0) into an EF.... so i assumed it was the same deal here
thanks
Modified by claytonsmith at 11:00 PM 10/10/2006
thanks
TitoSweetJr
10
08-11-2011 02:27 PM
