Which swap?
Which swap?
Which swap should I put in my car. I have a 1994 Civic Dx coupe. My plans are all motor, and i dont plan on doing a lot of internal work to it. Probably just cams/cam gears and a tune. I just want something that has a little more pep to it. Right now i still have the stock motor. Thanks for your oppinions.
Re: Which swap? (1995Civiccx)
first, let me slap the ricer right out of you by saying, all motor is extensive internal work. not just cams, bolt ons and a tune.
if you want to go all motor in the real sense, you'd be spending a **** load of money for massive internal work, and parts.
so basically all you want is bolt-ons and cams.
depending on what you like will decide youre ultimate motor, but i always recommend a gsr because its pretty much an all around motor.
look at the sticky at the top of the thread, it has all the pros/cons of all the commonly swapped motors.
Re: Which swap? (knockout)
Well i saw the sticky, but im still kinda confused on what motor to get. I was thinking about getting a B series motor, but i dont wanna spend a lot of a swap. So I was thinking B18B swap.
buy a gsr and put the ctr pistons in it.
pistons are about 130 yeilds power lil high then type r
for fraction of price
