tire rubbing on my quartepanel
1 Post
hi
my suspension is koni yellow adjustable shock and ground control coilovers , the rear tires rub too much on my quartel panel , I use 15 rotas slips my tires are 205/50/15 my friend say something about rolling the lip of the panel that would solve my problem , i adjust the shocks a little stiffer so they wont touch much it did help a little bit but not much
thanks for ur help
car is a 93 hatch cx
thanks for ur help
Re: tire rubbing on my quartepanel (super-hatch)
i would say change the camber but only if you dont care about tire wear.. i did and just bought new tires every two years
1 Post
Re: tire rubbing on my quartepanel (boostmyda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmyda »</TD></TR><TR><TD CLASS="quote">i would say change the camber but only if you dont care about tire wear.. i did and just bought new tires every two years</TD></TR></TABLE>
talking about the lip on the rear quartepanel were the tire rub with the lip of the quartepanel
Just use a baseball bat and roll the lip of the panel!! I had the same problem on my EG hatch but rolling the panel fixed it.
Re: (UberMunkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberMunkey »</TD></TR><TR><TD CLASS="quote">or try a 195 tire</TD></TR></TABLE>
I doubt he's using anything (if at all) much larger...
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch »</TD></TR><TR><TD CLASS="quote">hi
thanks for ur help
car is a 93 hatch cx </TD></TR></TABLE>
What tires are you using specifically? What is the wheel width and offset? What is the rear camber setting on both sides? Have you rolled the fender lip? Are you sure the fender lip is where the rubbing is occurring?
Adjusting more rebound force on the dampers won't do anything to help with this problem.
thanks for ur help
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">you have coil overs.
so raise your car
no more rubbing.
how low do you have it?</TD></TR></TABLE>
With the tires he's using it really shouldn't happen.
He must have it slammed.
so raise your car
no more rubbing.
ive got 15in GSRs with 95/55 series tires ground control coils and KYBs set on sport on my car and have no prob with the rear...
when i was rollin 205's on eibach spings it was about the same hieght and no prob either
theres about a finger clearence from the weel well to top of tire...
i only had to roll the front fender lips...
you must be slammed... raise the car a bit
SOHCMAN
01-15-2004 08:11 AM
