air conditioning/fan
i just got a ek hatch and the air conditioning doesnt work or the fan doesnt turn on... when i a moving i can feel air coming through the vents a little, but i try to turn on anything, such as ac, air, or heating none of them work... what could cause this problem?
anyway im trying to solve the problem and i removed the glove box and i found this...
anway... the red arrow points to a port where that green connecter can plug into...
but the green connector looks like the jumper for the CEL... and im afraid to plug that in because it might have something to do with the air bag...
does anyone know if that is for air conditioning...
Re: (meagainsttheworld)
that connector has nothing to do with the airbag for a fact all airbag connectors are yellow with yellow tubing so its def. not for your airbag
ill take a look today and see what it connects to on my car and let you know
i'm pretty sure that green connector is your fan control. plug it in and try it. if still nothing check the blower motor fuse...after that, if it still doesn't work you need to get the wiring schematic and test the wires in that green connector.
