Vitara piston install question. Need opinions...
I have vitara pistons and tuner toy rods. When I push in the wrip pins they go in as smooth as butter. Shouldn't there be some resistance. Wouldn't they slide left or right when installed. I'm afraid the pins might scratch my cylinder walls after the install. Anyone have any clue.
http://www.youtube.com/watch?v=wN32pW1xR7s
Re: Vitara piston install question. Need opinions... (Type-X)
vitara pistons are full floating so they should do that but there are to snap rings that hold the wrist pins in you should have those!
Re: Vitara piston install question. Need opinions... (seabass10369)
My pins were the opposite. Had to leave them in the freezer overnight to fit them. (hope that doesn't mean a problem down the road) The only difference in my setup is that I used eagle h-beams.
* B A N N E D *
Re: Vitara piston install question. Need opinions... (maynards_ek)
uhhhhhhhhhhhhhhhhhhh dude you have the wrong wrist pin!!!!!!! they should be pressed in most of the time, not to mention those pistons knck, anyways you are missing 2 snap rings
* B A N N E D *
Re: Vitara piston install question. Need opinions... (spork motorsports)
Why do people keep insisting that vitaras knock? Yes, there is a little piston slap, but it disappears after the engine is warm and oil is circulating. I was skeptical of them until I actually saw (and rode in) a car with them installed. He has been running them since may of last year and is yet to have a problem. (387hp) I chose vitaras as a cost effective alternative to brand-name forged pistons. They are loud at first, but any worries disappear when you lean on the go pedal.
* B A N N E D *
still a little bit of piston slap is bad, it will get worse over time, just like a motor that knocks now a little and will eventually get worse
Thanks for the replies but I found the locks that keep the pin from sliding like that. Yeah these are really for budget builders but if tuned right, these babies can make alot of power. Brand new for $50, who woudn't buy them.
Nichelson_Performance
06-30-2009 03:44 PM
crxrider07
03-14-2009 10:44 AM
11psiTurboSI
01-01-2004 11:19 AM
