1" master cylinder and 40/40 prop valve question
hey i have a 1993 civic 2dr ex that came with drums.....i have gsr front and rear suspension and i wanted to change the prop valve and master cylinder.....i have a 40/40 valve and a 1" master cylinder and booster.....my question is if anybody has a diagram for where the brake lines connect to the prop valve.....thanks
Re: 1" master cylinder and 40/40 prop valve question (malubawla)
Sounds like you might have ABS, if thats true you have to ditch the ABS to go with a 40/40 prop.
nah no abs....i have stock rear drums....i need to know how to hook up the lines to the prop valve from my brakes and 1" master cylinder.....someone has to know
Re: 1" master cylinder and 40/40 prop valve question (Luserkid)
your new prop valve is probly for abs not sure, u dont need to switch the booster from what i know just the MC
Re: 1" master cylinder and 40/40 prop valve question (7808)
i want to use the 1" master cylinder along with the booster and 40/40 prop valve.....i remember seeing a diagram on h-t before, but now i cant find it
i have full gsr suspension but still have the stock prop valve, master cylinder 13/16, and booster
i have the integra parts already, i need help for the brake lines
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">i wrote the how-to on 1" itr mc/bb swap
and i repeat:
You have an ABS prop, get a non-ABS unit and you wont have this problem</TD></TR></TABLE>
so the 40/40 is an abs prop valve......which one do i need then?
if i keep my stock booster and get a 15/16th master from a 91 civic, will i keep my same prop valve?
and i repeat:
not all 40/40s are abs...just most
you could use one from an RS, an em1 or ek hatch, del sol si
The prop valve "proportionalizes" the fluid, the MC just pushes the fluid around. Its not like "one has to go with the other" Its just the option.
Really, you can get away with not changing the prop at all (i would/did though)
Re: (pdiggitydogg)
which prop valve did you use......i got the prop valve from a 2001 integra ls, i dont know if it had abs......it has six ports, so i think its abs
Re: (malubawla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malubawla »</TD></TR><TR><TD CLASS="quote">which prop valve did you use......i got the prop valve from a 2001 integra ls, i dont know if it had abs......it has six ports, so i think its abs</TD></TR></TABLE>
Use an RS, they did not come with ABS.
Care to post a pic of a 40/40 prop valve? I did a swap on my del sol S to del sol VTEC brakes all the way around and I dont know if I have a 40/40 or not.
Does the S already have a 40/40?
I beleive its a DA rs valve, actually
try searching for it (going to be difficult since you need at least 3 letters for search though)
edit**
S is not 40/40
edit**
S is not 40/40
Re: (honda_racing101)
OP: yes for a 15/16th MC you can get it from the 91 honda civic sedan EX. Will bolt right up and all lines will be in the right place.
As far as prop valve I still use the one that came on my 92 cx and have no problems with my 4 wheel disc brakes. It is not neccessary. I hear it gives a little better pedal feel.
My brakes are just fine.
