turbos
turbos
just a quick question! when you buy a turbo kit like for instance greddy do they all come with a turbo controller?? and also if it does come with a turbo controller does this allow you to control how much boost your running or does that have to be tuned on the dyno?!?!?! i'm srry if this is a topic that has been posted before, or belongs some where else
Re: turbos (jfrase06)
wtf is a turbo controller? wastegates and boostcontrollers determine your boost level. greddy has an internal wastegate at 8? psi i believe. you need to do more reading, loooottttssss moorrrreee. dyno tuning is always a good idea when you go turbo. greddy comes with emanage which is a piggyback unit. good luck and you better use the search button more
* B A N N E D *
Re: turbos (hatchnideas)
the kit is a set limit becuase of the internal waste gate, you can up if by removing their wastegate and buying an adustable or you can use a hommade boost controller aka a grangier valve, which installs inline with your internal waste gate pressure line
* B A N N E D *
Re: turbos (spork motorsports)
als on your way to the dyno pull the upper most charge pipe so your car is stock with a turbo blowing air out somewhere random
thats what i did, but if you want you can run rich with the greddy magemnet piggyback POS
NCPolo2000
03-24-2005 02:58 AM
