JDM B16 swap having some problem need some help!
1 Post
Ok so the engine is installed but me and my mechanic are having some wiring problems... I don't know if any of you have some tips or tricks to figure out the wiring... also my shifter rods are to short what can I use instead? Maybe integra? Btw car is a 93 Si and the engine is a JDM B16A OBDI... plz any help would be appreciated!!!
David
David
Resident Gearhead
Re: JDM B16 swap having some problem need some help! (DaveSi677)
This has got to be the easiest Honda engine swap there is. The wiring from your old D16Z6 needs just a few mods. You need search the FAQ or "What swaps are available for my car" sections of this site. Everything is well documented about this simple swap all over the net.
1 Post
ok look at it but all I find is that I have to wire up a knock sensor... but is that all I have to do? For the shift rods/linkage 94 and up integra... so that solved that problem!
Any other things I should look at for the wiring?
Resident Gearhead
Some wires may need to be extended because your new motor is a little bigger than the old D. I'm not sure, maybe another member can help, but you might have to add wires for a 4-wire O2 sensor, the old one is a 2 wire I believe. Again, info for this swap is plastered throughout the 'net.
1 Post
Re: JDM B16 swap having some problem need some help! (mcvtec)
ok question.... can some one tell me when wiring the knock sensor to the ecu which pin do we wire it to???? picture or anything else would help...
Thanks alot guys this is much appreciated!!!
http://www.ff-squad.com/technet/
this is a link I found it should have what you need
1 Post
Re: (bigD)
Thanks guys for all the help... I spoke to my mechanic and everything is fine for the other stuff its just that the knock sensor wire can go to the D3 like on the diagram because he says that is for the O2 sensor... so my thinking is that when he got the engine they might of given him the wrong ecu cause on the ecu the code name for it is scratch out... so i think he has the wrong ecu!!!
What is the correct ecu I need... is it the P30 so I can tell him?
Thanks a bunch guys really appreciate you guys helping out even dough the questions have been answered already its just I am very limited on my time as I am in midterms and I have to study!!!!
1 Post
Re: (DaveSi677)
Some one plz help me! I know its annoying but I need the help!!! IF someone can just explain me how to fix this wiring problem so I can show my mechanic and he can take care of it!!!!
Re: (DaveSi677)
You already have been given the answer. Just have you p28 from your si chipped or get on of ebay and you will not have to run any wires for the knock sensor. If I am not mistaken you will also need the throtle cable from the integra yours will be a little bit short
1 Post
Re: (instructor74)
I don't want to chip the other ecu because I need to car to be running asap!!!! If I chip it, its going to take a least a week before I get the ecu back!
That is why I am trying to figure out this wiring issue... but its a little hard to understand so that is why I am asking the question so it can be clarified for me... I have knowledge in wiring!
fOmaNPu
21
11-28-2002 05:52 AM
