reverse light help on a swap (( SEARCHED BUT I GET THE SAME ANSWER))
the answer is ((SEARCH)) well i am gettin pretty tired of searching...
now time to post..
ive been havin this problem for about 5 months... no reverse .. i did a d to b swap on a ek and i see 2 green cables loose.. now im not sure if thats the right color cable for the reverse light and how it the clip looks or goes ... and the only thing i know that its around the tranny... any help please??
now time to post..
Re: reverse light help on a swap (SumOne)
clip them both in and see which one gives your reverse lights. ill try to get you a definate answer when i get home. ill look through my manuals. what transmission are you using?
why don't you calll when you have a problem? the problem is the morons who did you swap never connected the reverse from your tranny!
i'll connect it for $1000!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SumOne »</TD></TR><TR><TD CLASS="quote">
the only clip i find lose is the yellow and green... and i see that the one that connects to the tranny is GREEN and GREEN ... wtf</TD></TR></TABLE>
just get a new harness!
35600-P21-003 $26.00
http://www.thehondapartsstore....ch=no
then you can forget the cut wire and you'll be able to do it yourself and you'll know it new.
oh and that will be $100 just for telling you this, and providing the link!
i accept cash, money orders, and paypal. NO CHECKS!
Re: reverse light help on a swap (philosofy1)
and that suprise i had for u can go to my other boy...ek side skirts...
p.s. NO LINK WAS GIVIN!!! man i dont have no 26 bucks i went negative in my bank ... 5 times in a week... *** U b.o.a.!!
Just unscrew the reverse light switch and splice the wires longer and scavenge a pigtail from the junkyard or use quick disconnect male female terminals. The wires go either way they just complete a circuit. use a jumper and jump those two wires with the car off then put it in the on position and check the lights. -ejoner
Re: reverse light help on a swap (ejoner)
u know i had the same problem on my b16 swap the person that did my swap didnt hook up the reverse lights cause it was an auto to manual swap... so what i done was just run me a toggle switch and wire both my reverse bulbs up like they were fog lights (tied both my grounds together and both positives together) hooked the positive up to my ignition or switched 12V power (that way whenever the cars off if i accidently forget to turn the switch off the lights wont burn) and then i just hooked the ground wire to the toggle switch and got it from there.. heres the way i can explain cause i got tired of trying to find out what wire went where to. and i didnt wanna get my *** rearended.
sorry for the shitty pic but it will make u understand what i done.. OH and dont forget to fuse to just incase..
Re: reverse light help on a swap (david22ky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david22ky »</TD></TR><TR><TD CLASS="quote">u know i had the same problem on my b16 swap the person that did my swap didnt hook up the reverse lights cause it was an auto to manual swap... so what i done was just run me a toggle switch and wire both my reverse bulbs up like they were fog lights (tied both my grounds together and both positives together) hooked the positive up to my ignition or switched 12V power (that way whenever the cars off if i accidently forget to turn the switch off the lights wont burn) and then i just hooked the ground wire to the toggle switch and got it from there.. heres the way i can explain cause i got tired of trying to find out what wire went where to. and i didnt wanna get my *** rearended.
sorry for the shitty pic but it will make u understand what i done.. OH and dont forget to fuse to just incase.. </TD></TR></TABLE>
i dont want to ask how u turn on ur car... LOL but damn thats a raw *** idea but i know i can fix it .. i know im gettin juice from the cable with the grey clip... but when i try to check if i get circular juice from the cable that goes to the tranny i dont get any ... not even when the car is on and on reverse... can it be te sensor thing?? only one way to find out i guess.
