Code Questions
Old 10-13-2007, 12:12 PM
bkmc24's Avatar
Default Code Questions
I have a B16 in a civ. Basicaly i had my ECU rechipped and now i am hrowing Code 21. Is that because the chip didnt burn right or what? Its a CX ECU that someone half-assed the furst chip cuz i had no rev limiter and no VTEC then as well. Doesn anyone know anything about this?
Ben
Old 10-13-2007, 02:59 PM
bkmc24's Avatar
Default Re: Code Questions (bkmc24)
Anyone?
Old 10-13-2007, 03:50 PM
BlueIntegraBoy's Avatar
You are throwing a code for the VTEC solenoid, the reason why you are not getting VTEC (if your CX ECU was converted to use VTEC in the first place). First off, I wouldn't use a half-assed ECU. I would get a P28 and chip it to run a P30 program, or get a P30 ECU. Make sure your VTEC solenoid wired correctly or if it is still working.
Old 10-13-2007, 04:27 PM
bkmc24's Avatar
Default Re: Code Questions (BlueIntegraBoy)
Its not a half assed ECU anymore, the chip the guy ran on it i got it from doesnt know his *** from peanut butter when it comes to Crome. But ill take that advice on the p28 and get that done.
But still to answer my question, why is the CEL on now?
Old 10-13-2007, 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 &raquo;</TD></TR><TR><TD CLASS="quote">But still to answer my question, why is the CEL on now?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">You are throwing a code for the VTEC solenoid, the reason why you are not getting VTEC (if your CX ECU was converted to use VTEC in the first place). Make sure your VTEC solenoid is wired correctly or if it is still working.</TD></TR></TABLE>
Old 10-14-2007, 08:38 PM
bkmc24's Avatar
HOw do i check if its still working? Is there some sort of continuity check or something i can do to know this? I know vtec is wired also to take that out of the question.
Old 10-14-2007, 09:33 PM
https://honda-tech.com/zerothread?id=1503100
Old 10-15-2007, 08:39 AM
bkmc24's Avatar
Thank ya much
G'Funk
10-14-2006 10:56 AM
solerizr
09-05-2006 07:09 PM
asubennett
04-14-2006 03:57 PM
Eaglekper0046
04-03-2006 03:16 AM
self_made
08-08-2005 04:42 PM
Quick Reply: Code Questions
