5 lug conversion.ek
Re: 5 lug conversion.ek (BMRALR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMRALR »</TD></TR><TR><TD CLASS="quote">..but if i get CTR 5 lug conversion i can use my stock 32 mm axels on my 97 hatch. Correct me if im wrong. </TD></TR></TABLE>
This is correct
This is correct
Re: 5 lug conversion.ek (BlueIntegraBoy)
http://cgi.ebay.com/ebaymotors...wItem
Would thise particular kit for sale includes everything I need for complete swap. Is anything missing?
Re: (vti444)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 »</TD></TR><TR><TD CLASS="quote">on an ek is it poss to just buy rear itr bearings from honda and front bearings along with hub plate and bolt tsraight on to give the 5 stud conversion ?</TD></TR></TABLE>
If using the larger front knuckles (10.3" rotors), then you can buy hubs, bearings, and calipers to convert. I believe the EK4 does have the larger knuckle.
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
If using the larger front knuckles (10.3" rotors), then you can buy hubs, bearings, and calipers to convert. I believe the EK4 does have the larger knuckle.</TD></TR></TABLE>
im running legend 282mm brake setup already
your car has rear drum brakes right?
you will need better brake booster (integra), rear disc brake proportional valve from civic SI or integra , rear brake lines too.
here is some more info:
https://honda-tech.com/zerothread?id=2073128
https://honda-tech.com/zerothread?id=2068474
https://honda-tech.com/zerothread?id=2116747
and yeah, BUY CTR or USDM ITR 5 lugs or JDM CTR 32 mm, dont buy the JDM ITR one...such an hassle for 36mm hub.
i have 36mm, still working on the axles,
RhdRicheeee
11-21-2005 04:06 PM
