Rear wheel noise/ squeak
I have a 96 civic hath with KYB AGX shocks and H&R sport springs. The other day on my way back home from Anaheim (about 100 miles away) I heard a noise coming from the rear driver side wheel. It sounds like a chain is bouncing in the back when I go over rough road. Then if I take a sharp right hand turn it makes a squeaking sound from the same spot. At the same time that the squeaking sound is made it also sounds like metal on metal contact. I looked at the suspension pieces and everything looks fine. The rear rotors look good, Im going to take the calipers off tomorrow and see if something got stuck in there. Has anybody else had this problem? Any advice would be great. Thanks
Re: Rear wheel noise/ squeak (EKBOOSTDREAMS)
I got the same problem, just started out of no where. Let me know if you fix your problem, im going to take it apart this weekend.
It's a 99 civic si disc brakes if it matter!
turbotime
05-06-2007 03:21 PM
