one dim headlight
Old 10-12-2007, 05:04 PM
lumpylude's Avatar
Default one dim headlight
94 civic dx, just bought it, and just the right side headlight is dim... not the bulb, but both low and high beam on the right side is always dim. any suggestions? known fixes? thanks in advance guys. its also my first b-series, i'm excited
Old 10-12-2007, 05:07 PM
-Gambit-'s Avatar
Default Re: one dim headlight (lumpylude)
check your grounds.
Vt3c_eg's Avatar
try changing the bulbs and see if the lens is clear. sometimes the build up these tannish color which cause visualblity.
Old 10-12-2007, 05:21 PM
em1_fox's Avatar
Default Re: one dim headlight (Vt3c_eg)
also check if the wires r put correctly
Old 10-12-2007, 07:52 PM
Injen's Avatar
Default Re: one dim headlight (em1_fox)
Another thing.....check for burns in the wires. Alot of times when people put these "hyper white" or colored bulbs in the factory harness, it will just get to hot and melt the wires. But, in the process, it will make it dim before it burns up. I speak from past experience. You can buy new harness from the honda dealership for like $30 (pair)
Old 10-12-2007, 08:00 PM
Hardedge's Avatar
Default Re: one dim headlight (Injen)
I just put some Sylvania Silverstars into my car. Can I expect the wires to burn?
Old 10-12-2007, 09:14 PM
Injen's Avatar
you should be fine with the sylvanias. Its the high wattage bulbs like PIAA that are putting out 100, and some of the ones that you get of ebay. Alot of times it will say on the pack if they are intended for an aftermarket harness, but we always seem to look over that. I have seen the silverstars in PepBoys, and I believe they are just regualr wattage, just a different tone and lumens
Old 10-12-2007, 09:47 PM
Power of Dreams's Avatar
Default Re: (Injen)
Check both the ground connection and the condition of the wire harnes. A defect in either will increase the resistance of the circuit, thus decreasing the current and the brightness of the bulb(s).
Old 10-12-2007, 09:59 PM
hmtcrxsir's Avatar
Default Re: (Power of Dreams)
i would say check the bulb again because i had the same exact problem. It may look okay but you wouldnt know how long the previous owner used it. Try switching the good side with the bad side and see if its the same.
Old 10-12-2007, 10:04 PM
DCSportEJ1Civic's Avatar
if it has after market bulbs theres a chance it could be too high watts and melt the wires from too much heat. i had that problem on my civic.
Old 10-13-2007, 03:50 PM
lumpylude's Avatar
hey thanks guys, i'll try to look at the wires a little more. i can tell these bulbs ar aftermarket, but if i switch them, it makes no difference. so in the morning i will have a look see.
sixtodc2
06-01-2007 10:10 AM
deanh8
07-22-2006 11:07 AM
johnclaunch
05-03-2006 11:01 PM
emopinkgirl
09-06-2004 08:56 AM
BoM
Audio / Security / Video
11-20-2002 06:13 PM
Quick Reply: one dim headlight
