hard shifting
hard shifting
hey, after i changed the oil in my manual transmision, the shifting is different. i filled up oil through the side hole until it started to come out. but now when the car is off it shifts smooth and easy, but when car is running it becomes hard to get into 1 or even 2, but becomes easier when car starts moving. it wasnt like this before, so im guessing something went wrong during oil change.
imo its either there is too much oil or not enought. any ideas what could it be
Re: hard shifting (3lo)
try using redline light-weight shock proof gearoil. never did give me any wrong. got most of my racing buddies to use it..and while you in there..try puttin in some trans fix from lucas oils..hope that helps
Re: hard shifting (r8dr47)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r8dr47 »</TD></TR><TR><TD CLASS="quote">try using redline light-weight shock proof gearoil. never did give me any wrong. got most of my racing buddies to use it..and while you in there..try puttin in some trans fix from lucas oils..hope that helps</TD></TR></TABLE>
^^^I personally wouldn't use Redline--I've heard so many bad stories about that stuff.
I used to have a bit of trouble getting into 1st in my EM1. I put in Honda's MTF Advanced Formula (comes in a grey bottle, bright green label, and a white cap,) and now my shifting is sooper smooth. Try it out.
Re: hard shifting (EM-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM-One »</TD></TR><TR><TD CLASS="quote">I used to have a bit of trouble getting into 1st in my EM1. I put in Honda's MTF Advanced Formula (comes in a grey bottle, bright green label, and a white cap,) and now my shifting is sooper smooth. Try it out. </TD></TR></TABLE>
Man speaks the truth! no more third gear grind for me!
hard shifting?? must be Clutch is gone. Because shifting cant go 1st or 2nd gear. So check clutch if it's gone....that's what happen to me. my shifting wont go 1st gear and hard shifting
Re: hard shifting (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Remove the fill plug bolt from the tranny. Put the car on level ground. Remove the VSS and fill fluid through VSS hole until it pours out of the fill hole. Place back the VSS and fill plug bolt.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG »</TD></TR><TR><TD CLASS="quote">whats the level on the dip stick?</TD></TR></TABLE>
there is no dip stick on manual trany
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kiddox »</TD></TR><TR><TD CLASS="quote">hard shifting?? must be Clutch is gone. Because shifting cant go 1st or 2nd gear. So check clutch if it's gone....that's what happen to me. my shifting wont go 1st gear and hard shifting</TD></TR></TABLE>
it does go to 1 just hard, it wasnt like this with old oil, so no my clutch is good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mv1luv »</TD></TR><TR><TD CLASS="quote">also depends on the wieght of the oil you put in. </TD></TR></TABLE>
the closest dealer didnt have honda mtf, so i put some gear oil, must change that with honda mtf, didnt know it can be that different
well its pretty hard to fil when car is on level ground, what i did was lift it higher filled up 2 bottles and then leveled it to pour the extra out, why i have to disconnect vss ?
nocturnaldragon
44
06-18-2014 03:59 AM
AdRoz
Transmission & Drivetrain
06-14-2010 10:36 AM
