A big tune up for first time....need suggestion
I'm tryin to get the iridium IX for my tune up
but I don't know where should I get it
are they all different size ?
I found some at autozone but don't know if they will fit
plus the main concern is the wires
NGK have the wire set and the power cable
wt is the difference ? should I get the power cable ?
or wires like this on ebay
http://cgi.ebay.com/ebaymotors...ZWDVW
or this ?
and the O2 sensor should I get the NTK's one
thanks for too many question
or this ?
Needs More Cowbell
Re: A big tune up for first time....need suggestion (joe.wong321)
Just get the standard ngk plugs....those plugs that you want suck. Also just the standard ngk wires rock. I think that the other ones are a gimmick. Go to Honda and get a cap/rotor while you are at it.
I wouldn't change the o2 sensor unless it is throwing a code.
1 Post
Re: A big tune up for first time....need suggestion (HondaKyle)
go with ngk's they are great. and not expensive at all.
dont change you o2 sensor until it gives out on you. and also, go with stock distributor cap and rotor.
Needs More Cowbell
Re: A big tune up for first time....need suggestion (Dead CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC »</TD></TR><TR><TD CLASS="quote">go with ngk's they are great. and not expensive at all.
dont change you o2 sensor until it gives out on you. and also, go with stock distributor cap and rotor.</TD></TR></TABLE>
Is there an echo in here?
have to jump on band wagon here also....ngk plugs and wires are best. If you're dead set on replacing the o2 sensor, get it from the dealer. It's expensive, but it's oem and there is better quality control. I talked to a gentleman who trains emissions for state of utah, and he said there was a +30% failure rate on o2's from parts stores mainly due to shipping methods alone.
Re: (smog7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smog7 »</TD></TR><TR><TD CLASS="quote">so will a new o2 sensor improve mpg at all?</TD></TR></TABLE>
not really
not really
Don't I hv to replace the o2 sensor cos my CEL light giv me a code for that
plus my gasmilage is goin down from 28 to 22
Thanks
BTW, wt is the difference between the NGK wire set and the power cable?
Modified by joe.wong321 at 4:42 PM 12/9/2007
Thanks
anyone......
nobody know wt's the difference between the NGK wire set and the power cable ?
And are all the NGK spark plugs universal fit ?
cos I found some on ebay but said it's not for 99 si
Thanks
Thanks
no the spark plugs are not a universal fit. Just go to your local auto store and pick up the plugs. cause if u dont know what to look for they can help ya.
wesleychan18
07-18-2010 03:03 PM
