CEL question
CEL question
Ok first off my car is a 92cx hatch, with a jdm type r swap (b18c-r) with bolt ons a tune and 255lph fuel pump. I had been driving around with a bad Iacv sensor for a while now (3 weeks) and had no CEL's . (it idled at around 2.5 with surging idle after warmed up). Today I replaced it with a used one not sure what off of, runs awsome no problems at all. But now I have a CEL, Code 14 witch is the IACV... wierd? The car runs great still pops tech, but should I be concerned? It also said I was throwing a code 7 (TPS Sensor) but dont feel any thing wrong with the car... hmm input guys?? Thanks
Re: CEL question (Panda Eg6)
Not sure about the code 7, is that the sensor inside the dizzy maybe? Had problems with code 14 myself after turbo though. Im a dumbshit, so I thought it was a 1 and a 4 originally, replace o2 etc.....anyway, after replacing iacv, i still had code 14, started searching threads here and abroad, finally figured it out. Somewhere in the tech forums someone suggested a vacuum leak might be throwing the code for some reason. I'm too tired to remember why, but after crimping vacuum lines for a while i found the leak, replaced hose, clamped it, reset ecu, no more code 14, idles where it should. good luck....
scarface50370
12-14-2005 01:21 AM
Civic2Fast
02-11-2003 07:19 PM
