clutch installed no start
Ok guys I just did a clutch on the car. Went to start and it don't start, checked fuel and spark..cleaned the plugs. The only thing that I can think of is the timing maybe off.. How could this happen I mean i just did the clutch??WTF thanks again HT
Cool Cool Island Breezes. BOY-EE
Re: clutch installed no start (drevinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drevinder »</TD></TR><TR><TD CLASS="quote">check the ground on the tranny ...</TD></TR></TABLE>
Very important.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcxhatch »</TD></TR><TR><TD CLASS="quote">Ok guys I just did a clutch on the car. Went to start and it don't start, checked fuel and spark..cleaned the plugs. The only thing that I can think of is the timing maybe off.. How could this happen I mean i just did the clutch??WTF thanks again HT</TD></TR></TABLE>
Well...if your car was running fine before, the plugs and fuel delivery probably aren't the issue. You took off the trans. There's a lot of plugs and wires that you could have switched around or left unplugged.
The trans to chassis ground is VERY important. Then there's the starter wiring itself.
Besides that...more info would help...
Very important.
Re: clutch installed no start (jjo2036)
does it crank or does nothing happen? if it's nothing, you probably forgot to attach the trans ground...it won't do anything without it. if the ground is there and everything is plugged in, smack at the starter a few times and try to start it again...if nothing again, rinse and repeat (obviously no "rinsing involved). if it finally starts that way, the starter is bad.
if it cranks, not sure what you did...especially if it has fuel/spark.
Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 »</TD></TR><TR><TD CLASS="quote">Probably just the tranny ground...if not, just let us know!</TD></TR></TABLE>
Re: (slowcxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcxhatch »</TD></TR><TR><TD CLASS="quote">alright ill check tomorrow</TD></TR></TABLE>
Its tomorrow... Did you figure it out yet mane?
