combination light switch?!?! HELP!!!
well my headlights (both low and high beam) have ceased to light up. whenever I try to switch my headlights on, the high beam indicator always stays on, even if i try to switch it off. would it be a bad *combination light switch* or a bad fuse of some sort? thanx for everyones input in advance! Enjoy the holidays!
p.s. the headlights have not been altered in any way
p.s.1 the car is an ek hatchy
H-T White Ops
It's probably a bad combo switch. Well, the headlight side at least.
You can replace the switch by removing the steering wheel shroud (careful, the tabs on the sides like to break). There are two plugs, a larger and smaller one, plugged into the back. Pull those out. Then remove the two screws holding the headlight switch in. The switch will pull straight out.
Sometimes it might stick in there some.
alexflatfour
08-30-2016 01:11 PM
