need advice with engine
hey I got a 95 b18c1 and I later want to turbo it and build it so I got cp pistons but which ones do I get the flattop or the dipped like type ones? How about valve train and camshaft is the best for turbo setup. I want to make like 380hp. Can I go stock sleeves and stock crank?
Modified by rotascircuit at 1:25 PM 12/8/2007
Re: (aftershock2686)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aftershock2686 »</TD></TR><TR><TD CLASS="quote">how can you run itb's and a turbo ? i nrever heard such a thing</TD></TR></TABLE>
It's very possible
It's very possible
Re: (highlandparkbigpimpn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highlandparkbigpimpn »</TD></TR><TR><TD CLASS="quote">How in the ^&%# would that work all the pressure from the boost would blow it out of the ITB ?</TD></TR></TABLE>
What in the **** are you talking about? ITB's SUCK IN AIR.
Re: (cln92eg)
ITB stands for Individual Throttle bodies. How is a setup with ITBs and a plenuim not ITBs anymore? Look up Tonythetiger and check out the R32 Skyline design. If you have the money to engineer and time to fine tune a setup like it then youll be very quick. I would only use it on a race only app. No reason to do this on a street car.
Re: (cln92eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">ya but then it really isnt a ITB set up anymore lol </TD></TR></TABLE>
How is that? There is still 4 individual throttle body's right?
Re: (cln92eg)
yeah, its called a monster
ive seen it done at a car show, they had an almost adapter looking thing coming from the charge pipe, to a box, with pipes coming off the box into each throttle body
then he started the car.....too bad it was a DSM
sounded sick tho
sounded sick tho
Yeah, theres tons of cars that have it, done by bolting a plenum on top of the ITB's.
Alot of cars have ITB's OEM, like the Skyline, BMW m5, and are either factory turbo or commonly turbocharged and it works awesome.
Re: (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">
How is that? There is still 4 individual throttle body's right? </TD></TR></TABLE>
Ya there is but then its not cause theres not four different butterflies opening is there? Cause i dont see how
Re: (cln92eg)
Once its set up like that the intake side could be anywhere. For me personally i would have it on the bottom in the middle, that way when boost pressure is entered its evenly distributed.
Re: (cln92eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">Heres ITB's with a bolt on airbox
Heres a Golden Eagle Which is a sweet intake lol but they look close to the same
Please tell me you didn't just compare a regular I/M single tb setup to be identical to ITB's and a manifold
fukes
13
06-11-2004 10:26 AM
