Window won't close now...
I just parked my car at work, and started closing the window. It's power window's by the way in my 96 hatch. It get's to 3/4 the way closed, and I hear a snap. And the window won't move, the regulator seems to be working. Because I can hear the mechanism spinning if I push it to close. I know I'll have to take off the door panel to check it out. This sucks, what could have happened?
Look at where the mirror is, at that seal, is the window getting caught up on that seal? if it is then the window jumped out of the track, if that happenedd you most likely bent the regulator also. (this happened to me, i just put it back in the track and it would pop out every once in a while) If the window is jumping when it gets as far up as it can go then the teeth on the gear are worn too far. This happened to me and thats when i finally shelled out the money for a new regulator..
Re: (lee97ex)
fixed it!...took some time to figure out. But the plastic circular gear with teeth, some how managed to get itself off. I put it back on, and its opening and closing like normal.
smooz EK
11
12-05-2006 12:08 PM
EnKidu
10-10-2004 06:43 PM
