b18b what trans fits
ok all i need to know is what transmission that would be better(as of performance) would be able to fit on the b18b engine, can the d series trans fit it, say the d16y8 trans, would this be a good match
Re: b18b what trans fits (v8killaz)
You can make it fit with an adapter, but it's not only weaker but less aggressively geared. So no, that wouldn't make sense.
An Si/Sir transmission typically mated to a B16A is geared quite closely, and gears 1-3 are quite close. A GSR trans typically mated to a B18C1 will have slightly longer 1-3 but are stronger. A ITR trans mated to a B18C5 will have the best combination of both the closer gearing in 1-3 and the added durability. Take your pick. If you're looking for performance, avoid the LS trans as it's geared for economy.
Re: b18b what trans fits (iBear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8killaz »</TD></TR><TR><TD CLASS="quote">what transmission that would be better(as of performance)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBear »</TD></TR><TR><TD CLASS="quote">Any B series transmission will fit.</TD></TR></TABLE>
