weird noise in the rear
First of all I wanted to know does trailing arm bushing make noise when it goes bad?
I know for the fact that my trailing arm bushing are bad because at certant speed I could feel the rear end move side to side.
The noise sound like an old hinge on a door that is some where in the rear suspension.
It only happen when I turn hard or go at an angle.
Think yall could figure out where the noise coming from?
my suspension are skunk2 coilover , agx adjustable , skunk2 rear camber.
Re: weird noise in the rear (advan_turbo_gsr)
sounds like trailing arm bushings.. mine are done too, i have a rear disk swap from an integra and the bushings seem good so im all set, but if you replace them use OEM or Mugen, stay away from polyurethane
Re: weird noise in the rear (immajackuup)
how about aftermarket that look like oem?
plus how hard is it to a rear disk swap?
i wonder is bleeding it is a bitch to do.
http://www.rockauto.com/catalog/raframecatalog.php
gonna buy the 20 one
danno33
12
08-30-2009 07:19 AM
