ls/vtec ecu????
ls/vtec ecu????
apart from the cost$$$$. wats the best way to go with an ls/v setup. shud i use the p30. or will a chipped p28 do the same.
and can someone xplain wat the hondata s100 and s200 have in dif.
Re: ls/vtec ecu???? (wesley_925)
http://www.phearable.net hes good if oyu plan on turbo or any upgrade he will just send you a chip to the specs you want just pop out the old chip very easy he also sells s300 hondata stuff on the site just check it out for yourself.
Re: ls/vtec ecu???? (advan_turbo_gsr)
whoever is gonna tune your car, get the software that they are use to tuning with. but for start up, run a shipped p28 ecu with a itr map abd you should be fine until you hit the dyno
