Winding noise coming from engine bay......... Help
Old 02-22-2008, 06:38 PM
meandino's Avatar
Default Winding noise coming from engine bay......... Help
I tried to find another thread to bump or to look off of. No luck.
Here is what happened...
After work today I was driving home, and I heard a winding noise coming from about the middle of my engine bay. When I speed up it gets louder. When I slow down it gets softer. I push the clutch in, but it doesn't effect the noise. I pulled over to check it out, but didn't hear anything. There was a little bit of the CV axle fluid on the middle of the firewall -- driver side. I checked the boot and it's not torn, so there probably is a leak somewhere.
I started to drive some more. The noise sounded really bad with the acceleration, so I pulled over and shut the car off and looked in the engine bay. I noticed some snow on the passenger lower arm in the bay. I brushed it off and made sure my axles were fine. Then I started driving once more.
There was no more noise this last time. But I know that it didn't fix itself. I don't have anything to look for anymore and need to know what it could have been, so I can fix it before it comes back. What should I do?
I let my car warm up every time before I drive it, so the problem wouldn't be a cold engine, would it?
Thanks H-T
Old 02-22-2008, 10:25 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Help (meandino)
Old 02-22-2008, 11:04 PM
civic_coupe_585's Avatar
how many miles? has the water pump been changed at all?
Old 02-22-2008, 11:25 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Help (civic_coupe_585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_coupe_585 &raquo;</TD></TR><TR><TD CLASS="quote">how many miles? has the water pump been changed at all?</TD></TR></TABLE>
112,000 on a 92 Civic Si all stock. Just did a complete tune up with water pump, and everything you can think of.
Old 02-23-2008, 10:05 AM
meandino's Avatar
bump for help
Old 02-23-2008, 10:18 AM
93whtlx's Avatar
I had a throwout bearing do this to me once. I dunno if thats it. Just something that had happened to me. Hope that helped. How is your clutch.
Old 02-23-2008, 10:28 AM
meandino's Avatar
Default Re: (93whtlx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93whtlx &raquo;</TD></TR><TR><TD CLASS="quote">I had a throwout bearing do this to me once. I dunno if thats it. Just something that had happened to me. Hope that helped. How is your clutch. </TD></TR></TABLE>
Just barely replaced my clutch, pressure plate, throwout bearing, throwout bearing spring, tranny fluid, and tranny output gaskets.
Thanks anything else??
Old 02-23-2008, 12:14 PM
Antilag's Avatar
Default Re: (meandino)
Check your front bearings. Look for any small tears very carefully in your axle boot, since you stated it was on your firewall.
Old 02-23-2008, 12:15 PM
meandino's Avatar
Default Re: (Antilag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Antilag &raquo;</TD></TR><TR><TD CLASS="quote">Check your front bearings. Look for any small tears very carefully in your axle boot, since you stated it was on your firewall.</TD></TR></TABLE>
I'll get those checked out today. Thanks...
meandino
03-29-2008 10:43 AM
Mr. Lucky
Honda S2000
07-14-2005 04:37 AM
TypeR 508
03-09-2002 10:48 PM
Ibuprofen
01-10-2002 03:51 AM
Quick Reply: Winding noise coming from engine bay......... Help
