greddy turbo kit stock b16 safe?
would it be safe for me to put a greddy turbo kit on my 99 si with a stock motor about 70kmiles with hondata tuned for 8psi? daily driven. My friend told me i shouldn't do it because if i blow my motor i'm f*ck and if i turbo my car i should do it to a newer motor.
Re: greddy turbo kit stock b16 safe? (99_red_si)
putting the turbo kit should be fine as long as its tuned right. Make sure you have the right fuel upgrade and do a compression test like the other guys said.. I wouldnt use the greddy emanage use the hondata...
Man U FTW
The rule of thumb for a stock block B series on pump gas is that you're safe at 300whp or less. You can make more but it takes a good setup and a good tune. If you come close to 300whp on your Greddy setup, consider yourself lucky....you'll be fine on the stock block though
CivicGSR225
06-17-2004 11:54 AM
