arp headstud help
arp headstud help
ok guys i did a ls/vtec but i think i got the wrong headstuds on ebay they said ls/vtec & b20/vtec product num 208-4306 but we put them on & now theres oil in my 1 & 3 cyl could the headstuds be the problem help me out guy thanxs
Re: arp headstud help (Luserkid)
headgaskest is new but i also wus thinking hg so i bought a new 1 but i dont wanna put it on if it do the same thing i wanna find out if b20 headstuds will work on b18a with a b16 head its pissin me of haveing at home just sittin there
Re: arp headstud help (tazzsi84)
208-4303 is the part number that you need. It is the same number for a GSR. these are the head studs i am currently using in my setup. Maybe you didnt torque the head to spec.
Re: arp headstud help (lluks_844)
could have put the head gasket on upside down. guy i used to work did it on a h23 and it spewed oil from between the block and head
Re: arp headstud help (nub)
I think coolant would be in the oil if the headgasket was upside down,it is not as uncommon as people think i had done it with my cometic gasket tho. lol honest mistake
Modified by lluks_844 at 2:03 PM 2/21/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">i am under impression that all b series headsutds are the same but not sure about b20</TD></TR></TABLE> 208-4202 - Ls
208-4303 - gsr
208-4306 - b20 w/b16 head
208-4301 - b16a
208-4303 - gsr
208-4301 - b16a
so basically i cant use the studs i have is ther anyway possible they could be used im just tight on money right and no therse no coolant in my oil just oil burning like hell in num 1 & 3 cyl num 3 has the most dont know why here are sum pics of the num 1 & 3 cyl exhaust ports
number1
number3
number1
number3
???????? anybody come on is it posible to use the b20 headstuds from arp 208-4306 on a b18a for ls/vtec can they be used
Modified by tazzsi84 at 2:54 PM 2/22/2008
what head gasket did you use??? one from your lsvtec kit or a honda head gasket?? i hear that some of the head gasket from kits are poopy
well we used the 1 that came wit the lsv kit i have a new honda 1 just not tryin to mess it up if its the studs thats giving me prblems and yes we pluged the oil hole in the head wit the skrew that came with the kit its my first build n relly dont know wtf is up it sounds good and everything but its burning oil like hell should i just change the headgasket to see if it stops
Re: (2redstars)
so it cant be the studs those can be used with my setup cause i hear u can then u cant i dont kno wtf to belive i just wanna get my running
Re: (2redstars)
ok but i have b18a with a b16 head not b20with b16 head dont know if it matters but if it does sum 1 please let me know
on my ls-v swaps and crvtec swaps i use the gsr stud i think b20 studs are longer than gsr and for ls a ls(81mm) a ls head gasket and for b20(84mm) a b20 head gasket
Re: (serio_ENDLESS)
Make sure that you torque your studs down correctly, easiest way to start troubleshooting in this case. They need to be torqued in a specific order as well. If you search around honda-tech.com, you're bound to find them. I did when I needed them.
Honestly the headgasket is wrong and if you can torque the studs your stright im currently building and i need the right headstuds studs?????????
tazzsi84
24
03-07-2009 05:10 PM
