Seats
Seats
is it possible to put 95 GSR seats in my 97 hatch without modifying any interior panels? i know the front ones should bolt straight up to my stock rails but im concerned about the back seat whether or not it will bolt straight in
Re: Seats (Fullthrottle297)
I'm pretty sure if you searched you could find something faster. But for a hatch you must use the rear seats from a 2 door integra. some one correct me if i'm wrong please.
I just put 97 integra seats into my 96 hatch. I had to change out the inner rails with the ones from my civic seats for the front. There is a write up on here somewhere. The rear seats DO NOT fit. I was able to use the upper portion of the back seats (the ones that fold down), but I had to strip them both down to just frames. The Integra frames won't fit in the hatch unless you do some fabrication. I just removed all of them little bent wires that holds the cloth to the frame and re-upholstered onto the civic frames. As for the back seat (where your butt goes) good luck, the mounts are all off. The write up that I followed the guy re-upholstered onto the civic frame and then used a sewing machine to add the additional material. He went above and beyond, for that OEM look, but couldn't find exact matching material. Personally nobody climbs in the back, so I just have it sitting in there with the seat belts buckled.
https://honda-tech.com/zerothread?id=1436635 how to for the seats
Modified by Kingcobra33 at 11:36 AM 6/3/2008
Jake Pwns Hard
11-11-2008 03:05 PM
