Timing Belt question
I was wondering if a timing belt that is soon in need of changing would cause a CEL? Im currently looking at a 97 civic ex and the seller claims that the CEL is because the timing belt really needs to be changed soon.
No, a timing belt won't cause a CEL, the owner is lying. A broken timing belt will cause several check engine lights because your engine gets pretty screwed up.
Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">No, a timing belt won't cause a CEL, the owner is lying. A broken timing belt will cause several check engine lights because your engine gets pretty screwed up.</TD></TR></TABLE>
Re: (OMGWTFBBQ!)
with a broken timing belt your motor would not be running
Re: (EGhatch87)
Yeah you can get autozone to check your codes, or you could bypass the pin connector and find out the code yourself. Timing will nott throw a cel.
imadigitalgod
08-18-2023 08:01 PM
