Throttle Question ?
Re: Throttle Question ? (OMGWTFBBQ!)
i have a aftermarket TB, but when i set it to 0% i can only get it to open to 85.7%, shouldnt it be opening all the way to 100 % ?
Re: Throttle Question ? (Joeski99Si)
How are you measuring 100% ? mecanically or with the tps outout voltage ? is the tps idle voltage set correctly, if it doesn't reach 100% output voltage for your car then maybe as before mentioned, the throttle cable needs ajusting or maybe the cam is the wrong ratio for your setup.
Drew96EJ
11-02-2003 03:05 AM
