HELP Code 43 95 civic EX
ok so my girlfriends car would not start for some reason last night after a bunch of cranking it started I parked it and it shut off again. I checked the codes besides the code 10 I was gonna fix this weekend its throwing code 43 fuel supply system, and Code 1 02 I did my research and most of the time they say its the 02 so since I got an 02 code at the same time I got 43 does anyone besides me think that is def the problem I just wana know before I buy one because they said I can't return it when I'm done.
+Fuel pump turns on
+not the Fuel Pressure Regulator
+Injectors are pulsing injectors are fine and Harness has the proper voltage resistance is good on the injectors.
Modified by godzhand at 8:59 AM 5/30/2008
+Fuel pump turns on
