Weird problem
Weird problem
I had some water down in the cylinder where the spark plugs go , and it was causing my car to miss fire. I pump it all out and cleaned it up and as soon as i put it back my car ran a bit weird sounded like a WRX. I change the plugs and the wires and it runs more normal but, when i pull the spark plug wire out of cylinders one or two the car doesnt really change, but if i pull three or four it boggs down a bit like it suppost to. I was wondering what could be the problem anyone have any suggestions?
Re: Weird problem (z6hatchboy)
i have the right firing order. I did a compression test and all but cylinder 2 was at 220, cylinder 2 itself was at 205. its a 00 B16A. i recently changed the cap, rotor, PVC, Wires, Plugs, and Coil about 500 miles ago. It drive fine right now but i was curious way cylinders 1 and 2 wont drop the RPM's like 3 or 4.
Modified by Speed_1 at 8:12 AM 5/30/2008
i was cleaning up the motor, and i guess it leak through the spark plug cover, and through the wires. atleast i hope thats how it got there, other then that i dont see any other way.
Pudnite
02-11-2018 04:46 PM
ThaReason
11-08-2003 08:44 PM
