del sol no start
del sol no start
Posting this for a friend
94 del sol gsr swap, car ran fine, swapped bad transmission out and put another in, started with tranny on with no axles inserted yet, inserted axles and finished up, went to start and no spark/fuel. He said he checked grounds even hooked up extra ground, checked fuses, switched main relay with 2 good ones, switched harnesses, switched distributors. fuel pump does not prime and no spark, helppppppp
Re: del sol no start
Most likely a bad ground or a popped fuse.
Clean and tighten the critical ground wire attached to the thermostat housing.
There are three main relay fuses. One under the hood (#31) and two under the dash (#18 and #24). Replace them with known good fuses.
sivad84
10-29-2011 06:02 PM
