Water getting in Thru Sunroof
hey guys wats up
well im having a problem with my 95 civic si
whenever it rains or i wash my car water gets inside my car thru the sunroof
i called the local honda dealer for parts to see if i can buy a new seal that goes around the sunroof and they say they dont sell it by itself that it comes together with the glass and thats like $600.00 any one knows what can i do to prevent water from getting inside my car?
or something??? ughhhh
thanks for looking
thanks for looking
Re: Water getting in Thru Sunroof
It might not be your seal...
Sometimes the drains get clogged with leaves and dirt....try using an air compressor and gently blowing air through them.
318 Curves, 11 miles
It's normal for sunroofs to collect some moisture, or even a bit of water in a heavy downpour. Honda thoughtfully provided the nice little drip tray that goes around the sunroof and channels the water into draintubes.
Most leaky sunroof problems I've seen on Civics seem to be caused by problems with the draintubes. Unless you can actually see it leaking profusely around the sunroof seal, I'd start there.
bump
i tried using an air compressor so i can unclogged the drain if its clogged with leaves and dirt and it still didnt work anyone knows something else
run the hose on the roof, sit inside the car and find out where it's coming in.
years of parking under trees, dirt, buildup on the roof will clog drains, which will cause moisture to sit in the dirt/smeg/shtuff around drain holes (even if they aren't plugged) this can cause rust to form, eventually rusting through and creating holes where moisture can penetrate.
you've got to find the source of the leak before you can fix it. Take off the headliner or whatever else is in the way and find out where the water is comin in. simple simple easy peasy...
best of luck, leaking cars can be a hassle. what sucks is when you don't fix it and the car stays wet inside and starts smelling like mold.
dlenoxx
12-02-2010 12:05 PM
