y7 catalytic on y8 pass smog?
Old 10-27-2009, 06:08 PM
d1nki's Avatar
Default y7 catalytic on y8 pass smog?
So I hae a d16y8 in my ek right now. I have a d16y7 exhaust manifold with cat just laying around. Will I still be able to pass smog with the y7 catalytic on my y8? I mean isn't it still obd2 and uses 2 o2 sensors? Another questions, my car leaks oil a little, will that affect smog?
Old 10-27-2009, 07:52 PM
gwl
gwl's Avatar
Default Re: y7 catalytic on y8 pass smog?
I don't see why not except the O2 sensors wires may be a little long with Y7 cat. Th oil leak shouldn't matter not unless it's dripping at a fast rate on the exhaust causing to smoke.
Old 10-27-2009, 10:30 PM
honisoto's Avatar
yes you can use it and No it wont effect unless its super dripping oil. lol....
Old 10-27-2009, 10:37 PM
d1nki's Avatar
Alright awesome because the y8 catalytic converter is hard to locate dude. And no oil is not dripping that fast. Just want to get emissions out of the way so I can start rebuilding the motor. woohoo
Old 10-28-2009, 05:48 AM
gwl
gwl's Avatar
I would think the Y7 cat will be hard to find. A lot of them suffered the cracked exhaust manifold syndrome. The Y5 and Y7 cats were welded to the exhaust manifold.
Old 10-28-2009, 06:05 AM
HCivExoo's Avatar
yeah the wiring to get the O2 sensors in the right spot are the only thing that make that more trouble than just changing it with the correct cat.
Old 10-28-2009, 10:37 AM
d1nki's Avatar
Well I my car is a dx so it came with the y7 originally. The wires for the o2 are right there and my cat is perfectly fine, I hope.
Old 10-28-2009, 02:41 PM
HCivExoo's Avatar
the Y7 cat is fine on the Y8 just going to rob you of hp but i am sure you are aware of that. if your other cat is fine you should be able to pass smog though, have you tried replacing the Y8 cat?
Old 10-29-2009, 01:14 AM
d1nki's Avatar
Thats the thing, I never had a y8 cat. I just picked up a y8 longblock. I just need the y7 cat to pass smog. Once I am done with that, the turbo kit is going back on.
Old 10-29-2009, 06:29 PM
honisoto's Avatar
yep you should pass no problems.
swizz977
06-05-2015 06:21 AM
DontTouchMyEj1
06-16-2013 10:58 PM
oneEg1Tc
07-21-2011 08:30 PM
jiggatone
09-16-2008 05:29 PM
jahasiel
03-24-2007 02:49 PM
Quick Reply: y7 catalytic on y8 pass smog?
