new ride. 92 dx hatch, imported
ok so i sold the 93 sedan, and bought a 92 DX hatch for $1500. its a canadian car. it came without a passenger mirror, and it does not have parking lights in the front. it has city lights instead.
its a d15b7 with a 5 speed manual. im surprised tho, because it is faster than my sedan, even after i did the d16z6 and SI 5 speed swap. so i can't wait to try the b16 or b18 swap this summer after i save some money up, along with the 5.4L swap for my thunderbird.
heres some pics.
and by the way, ive already swapped out the gay "no tach" cluster, for the cluster out of my 93 sedan. just swapped my speedo into the lx cluster so it has a tach now.
what does the red sticker say? i can't read german.
heres some pics.
Re: new ride. 92 dx hatch, imported
I'm not positive, but I think that's when your next service is due. Probably oil change, tire rotation, etc. I know "wechsel" means change or change-over.
fm
fm
it has city lights however, no parking lights, not even a wire in the harness for them. and it has a factory rear fog lamp.
the girl i bought it from owned it since 2005 and the guy she bought it from worked for majestic honda.
im worried more about performance then how it looks. but i do want it to look ok, but i dont want it to stand out.
idk what im gonna do about the city lights tho. its already inspected, but idk how the inspection station will look at that, since i dont have any parking lights up front.
Seagull Management
the girl i bought it from owned it since 2005 and the guy she bought it from worked for majestic honda.[/quote]
Canada started the DRL law in 1990, it requires all vehicles made or imported after January 1/1990 to have DRLs
I'm not saying that isn't true, but its unlikely. We don't have to put Canadian clusters in US vehicles to import them (my father owns a '97 imported Tacoma with original US cluster in MPH)
None of that is Canadian. I highly suspect you have a Canadian made US civic the same as every other person that seems to think just because the core support says Honda Canada on it, it was imported. I'm not trying to be a dick, i'm just trying to stop the spread of wrong information.
but in the us u have to have a mph cluster. i had a jdm cluster in my last civic, and it failed inspection because of it.
Oh look, I can change this
I'm going to have to side with 94EG8 on this one, at least for now. Though, I will say there are some curious things about your car that make it at least a little bit interesting...
First, the bad news:
- Canadian 5th Gen Civics have DRLs. Without exception. You can tell this by the large yellow-labeled resistor in the driver's side corner of your engine bay, near the master brake cylinder. #3 in the image below.
- Canadian Civic DXs came with a passenger side rear-view mirror. Without exception. It could have been removed by a previous owner (don't see why, though!).
- However, Canadian CXs DID have optional rear-wipers and side mouldings, and COULD come without the passenger side mirror. They also came stock with the D15B7. Without exception. (NOT the D15B8, like in the US.)
- I can't see if your car has SRS. ALL USDM 5th Gen Civics have SRS. However, though I am not 100%, I am pretty sure that Canadian 1992 DXs did NOT have SRS. SRS was even optional (or non-existent) on the 1992 Canadian Si, so I doubt that the DXs got them as a standard feature, though it's conceivable that it was an option on the DX. SRS was NOT available on the Canadian CX and VX, however. (See my post here for more info on the 1992 Si steering wheel: https://honda-tech.com/forums/showpo...&postcount=386)
- A Canadian vehicle imported to the US would not LEGALLY have to swap out the cluster, as a Canadian cluster shows mph around the inner circle of the speedometer. (Opposite of a USDM cluster.) An owner might want to as it would get annoying looking at km/h outer markings all the time. Your JDM cluster did not pass inspection because it did not have mph markings.
- I am curious as to why there are some EDM-type options on your car. City lights? Rear fog light? Not even wired for parking lights? A German service sticker? Could be something, could be nothing. Very interesting, nonetheless. That big Honda of Canada sticker is not a good sign, though, nor is the lack of sidemarkers.
- Can you provide some more pictures? Am interested your no front parking light problem, and how the rear fog light is set up. More interior shots would be great.
- Can you provide the first 11 digits of your VIN? This will in no way identify your car, nor can it be used for nefarious purposes. It will tell me the make and model, however, as well as where it was built.
met the original owner finally. heres the story.
he bought the car new in 92. the city lights, and rear fog lights were factory, they were a dealer installed option, he was planning on moving to europe. he went to germany in 93 and came back in the end of 93. he moved to the states in 94 and changed out the cluster to mph and removed the DRL.
after i met him, he had me come back the next day and he had a box he had parts in it for the car, including the original km/h cluster that only shows 24,534 kms, a spare distributor, and the DRL set up.
Last edited by 92lxsleeper; 07-29-2010 at 10:15 PM. Reason: met owner, clearing story up.
The sticker says: "Next Brake Fluid Change By: xxxx Kilometer, At the latest on: 6/04.
Here is a thought on the car. It could have been imported into Germany by a Canadian (Military?). They would have had to gotten a TUV certification/inspection which may have required some of the parts to be changed to meet TUV spec.
The German market 92-95 Civic's are a bit weird. Here is how the CX/DX trim level hatchbacks come:
-1.4L carburated engine... yes all the way through 1995
-JDM style side markers
-Alternate rear hatch for Euro style license plate
-Clear corner lamps
-Metric gauges
-JDM style bumpers with rub strips (*edit... this is only on the Ek models, not EG. But they do have a 92-95 civic station wagon here)
So for me I'd say for sure this is not a German market car, but that it likely was in Germany.
If you want to check out specs or pictures on German market cars check out this used car site:
www.autoscout24.de
-Clear corner lamps
-Metric gauges
www.autoscout24.de
Ausmith, I suspect you're right. That car has probably been to Germany and back. Military is a good guess, or else visiting academic or other professional.
OP: I await your pictures! And that VIN checks out as a DX trim. Does it have the DRL resistor in the corner of the engine bay?
heres some pics of the rear fog, and city lights. its 1am almost so its hard to see, but you wont be able to see a difference in the daylight.
