d16z6 help plz
d16z6 help plz
so we got a ex for an everyday drive for now we got it with broken timing belt took it apart vavles looked ok so put new belt n threw it togethr we go to start n turns over but no spark or fuel? were takeing 1 step at a time i switchd dizzy with known wrking one and nothin but had to reuse cap and rotar off 1st one still nothing n e help? i switchd wires alredy, fuel prob wil be ez i jus need to figure, idk y no spark timeing is correct
Re: d16z6 help plz
1) Check for blown fuses under the dash and hood (e.g., 18, 24, 31).
2) Check whether the important ground wire attached to the thermostat housing is clean and tight.
Re: d16z6 help plz
1 u cant tell if. Valves are vent. By just looking
2 try. Chek. Fuel pump. Hear prime ? Or just remove. Hose fromnend. Of the fpr see if when u turn ignition
3 have. U conected dizzy. Rite. There is plenty people. Switch. Wires
Re: d16z6 help plz
well i switch the dizzy ill check the fuses and gounds after work, and the we havent got to the fuel part ytt also the car has an alarm you think possible kill switch? i tryed disconnecting the alarm and starting but still no luck
Re: d16z6 help plz
so we got a ex for an everyday drive for now we got it with broken timing belt took it apart vavles looked ok. So put new belt n threw it togethr we go to start n turns over but no spark or fuel? Were takeing 1 step at a time i switchd dizzy with known wrking one and nothin but had to reuse cap and rotar off 1st one still nothing n e help? I switchd wires alredy, fuel prob wil be ez i jus need to figure, idk y no spark timeing is correct
glockoma818
05-01-2012 02:43 AM
plantmylotus
10
10-14-2008 10:49 AM
