I cant get my wheels off...Help!
When I bought my 96 Civic EX it came with aftermarket Velox wheels on it. Sadly I didn't know that the lug nuts are irregular and nothing will loosen them unless you have a special tool. Now I have a flat and I cant get my wheel off and I do not want to fork over the money to go to a machine shop.
Is there anything I can do to get them off myself? Also the two front wheels have key on them and I don't have that either. Is there a specialty on-line retailer that sells those (I have already tried all the wheel stores around and NAPA)
Thanks for the help.
Re: I cant get my wheels off...Help!
Just go to an actual tire shop. Most of them have the tools lying around or you can purchase just the tool from them. I had this scenerio once. It cost me 8 dollars for the key, at a local mom an pop tire shop
chuck norris would pull it off bare handed. (username)
do you know what kind of lugs they are? gorillas, rays etc. post up a pick. i work for a tire shop and get them off almost on a weekly basis
1 Post
Yeah he would hold on to the lug nut with one hand, and lift the car and rotate it to spin the lug nut off with the other.
Not that he's dumb; he's just that strong!
Ps how many locks on each tire? If its 1 per tire, you can take the other 3 off and wiggle that last lock lug nut off. Just keep tugging on it. It'll break off the wheel stud but it depends on how desperate you are.
Post pics to see what u got
i would go to a tire shop. if one of those other methods fail to work, a tire shop will be useless. take a pic of it if u cant get the car there. maybe they can still help u out
What you do is u take a socket set (it MUST be 12 point, a prefferably 1/2'' drive), and you find a socket slightly smaller than the lug/lock you are trying to remove. Then you hammer the socket onto the lug/lock as far and as evenly as you can. You then take a repespective breaker bar and break the nut free.
To get the lug/lock out of your socket, take a punch and go through the socket wrench side and hammer it out.
Its really easy if you have the tools. If not, take it to a tire shop (Firestone, cuz thats where I work...lol). It will save you time and the headache of doing it yourself w/o the proper tools.
Park your car on the south side... I'll be gone in an hour.... Sitting on bricks....
Go to pepboys, autozone, etc website, and look at thier wheel locks... Most likely you'll find the right one in there, buy it, use it , and then return it...
1 Post
Ding ding ding ding light bulb!
Use the GATOR GRIP socket! Fits all shapes and sizes. Within/up to 20mm nuts and bolts.
I got mine at kmart for $10 and it came with a "made in taiwan" ratchet for free.
Or vice grips, or a grinder or combination of tools.
What methods exactly have you used?
