Aftermarket Radio stolen now Heater doesn't work?
Ok, guys Im new to the forum but I have used the info from Honda-tech many many times. Has helped me figure stuff out and saved me a buck or two at least 80 times.
So heres the deal Im lost. Bout a month ago someone broke into my 96 dx and stole my Radio and some other odds and ends (think took whatever they needed ) now my normally GREAT heat of the sun heater isn't working.
Can anyone give me some advice on what to do? I thought I checked the connections but then again I don't have a clue what connections to check. Environment controls are something I'm not good at aka a/c & heater
Re: Aftermarket Radio stolen now Heater doesn't work?
Did you check the actual mechanical cable that opens and closes the valve to allow coolant into the core?
If you are equipped with A/C, does that work? Is the blower working, but just not blowing warm air?
I checked that cable ya. Connected but my understanding is that if they steal the rado sometimes it'll get loose and that will mess it up?
My a/c blows cool air not frigid. Blower is working just now blowing hot air.
ya well I toyed with the air mix control cable thinking it might be loose. seems to have made the heater actually warm up. Only issue I have is they messed up the wires so bad that when you turn the switch from off to say 1 my a/c light comes on like Im turning on the a/c even if I had the button next to it pressed before hand. The little car circulation air one. lol cant remember what its called atm.
ppl talk bout my old name
12-21-2005 02:15 PM
projectej8
08-14-2005 02:43 AM
