D15B8 harmonic balancer special tool to install: where do I get one?
Im installing a crank pulley/ harmonic balancer on a D15B8 cx motor and need the special tool so that I can get it TQ'ed to 145 Ftlbs. The pulley has 8 holes around it. Where can I get the special tool? herea a link to the harmonic balancer. http://www.partsgeek.com/catalog/199...ft_pulley.html
part #W0133-1609466
second one from the top. Thanks for any help
part #W0133-1609466
Re: D15B8 harmonic balancer special tool to install: where do I get one?
i just used an allen wrench or screw driver to block/hold it in place on my b18c1 when i was changing over itr cams. just an idea...i heard u can get the tool at sears though...
ill check sears, I need one different than the typical hex shaped holder because inside the pulley its round. I tried a big craftsman screwdriver but it bent it. The TQ is 145ftlbs. I have one of the new style crank bolts with a 10 printed on the end
PHANTOM MENACE
You might be able to get away with leaving the car in gear and having a friend press the brakes while you torque (or remove) the bolt. Of course this is assuming the engine is in the car.
How is pushing the brakes going to stop the harmonic balancer from turning? lol
Ohhhh okay haha makes sense.
Can you not use an impact gun with a torque stick for the correct about of torque needed?
94vtecmn
04-21-2003 12:08 PM
