95 civic DX "distributor out of room for adjustment"
Old 03-11-2011, 12:55 PM
dungeonKing's Avatar
Default 95 civic DX "distributor out of room for adjustment"
I changed a head gasket in this car and can't seem to get the ignition timing correct.
Judging from the marks on either side of the cam gear, that line up almost perfectly with the top of the head while the bottom end is at perfect TDC, i feel like mechanical timing is not an issue.
The distributor is currently pulled away from the firewall as far as it can go. I still need to retard the timing just a bit more.
Maybe i need to move the cam gear a tooth one way or the other??? not sure
Any help is greatly appreciated...thanks in advance
Old 03-11-2011, 01:50 PM
MonkeyMagic's Avatar
Default Re: 95 civic DX "distributor out of room for adjustment"
you are either looking at the wrong marks for the timing or mechanical timing is off.
Old 03-11-2011, 02:12 PM
Seagull Management
94EG8's Avatar
That or the OP didn't jump the service connector under the dash.
Old 03-11-2011, 02:28 PM
timing at idle would never be that far off. connected, jumped, or otherwise.
Old 03-11-2011, 04:54 PM
i definitely jumped the service connector, i'm gonna have to agree that i should adjust the mechanical timing to solve the problem.
XVNVX
08-07-2017 10:31 AM
Justephen Sae
02-01-2015 08:20 AM
verle89
06-02-2014 05:47 AM
crooked muffler
30
03-03-2006 05:31 PM
integ u
08-05-2003 09:39 AM
Quick Reply: 95 civic DX "distributor out of room for adjustment"
