96 Civic Accelerator Cable
My 96 civic ex coupe accelerator cable has freyed loose strands.
Are there any tips, tricks or traps that I should know about before getting started replacing the accelerator cable? Good place to buy one? Thanks
Resident Gearhead
Re: 96 Civic Accelerator Cable
Pretty easy to do, the only PITA is working under the dash to get at it. Don't make it too loose or too tight.
Buy a new one from http://www.hondaautomotiveparts.com/ they sell them for cheap.
Look under 'Pedal' and it's listed as a 'Wire, Throttle'.
Yes there's a plastic piece (yellowish)that sort of locks the pedal side end of the accelerator cable in place that sometimes breaks when you remove it-it pushes on and pulls off, I could not get the pic to show from the link to tell you also the cable is held on at the firewall (engine compartment-side) all you do is twist to loosen the plastic "plug" to remove the cable should take you a total of about 10 minutes or so to do
Thank you very much gentlemen.
What a great resource Majestic Honda website and your expert guidance to the part I need.
"...twist loosen the plug", check
About that yellow plastic piece; if it breaks, am I hosed? How do I - don't do that, lol.
Looks like I'll order up one of these: 17910-S01-A02 008 001 WIRE, THROTTLE 18.00 12.60.
I wonder if any of these items below are necessary.
17921-SA4-730 009 001 SEAL, THROTTLE CABLE 4.88 3.42
17931-SR3-A01 011 001 CLAMP, THROTTLE WIRE 15.00 10.50
17932-S04-A00 013 001 CLAMP, THROTTLE WIRE 13.13 9.19
Best Regards
Mark
Best Regards
Mark
FeelTheBass
02-08-2015 09:42 PM
