Oil leak, help find where its from!
98 GSR in 95 hatch...
The car is leaking oil bad..the pan is not torn, and its not coming from the oilfilter or plug...help me find it. It is running down to where the shift linkage is connected to the trans. Any ideas would be helpfull.
Re: Oil leak, help find where its from! (blykins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blykins »</TD></TR><TR><TD CLASS="quote">Rear main seal.</TD></TR></TABLE>
yep. not that hard to change, just a little time consuming.
Re: Oil leak, help find where its from! (vtecb20coupe)
any one have a walkthrough for it? Im doing clutch, and new trans next week, is it going 2 be accessable while the trans is out?
Re: Oil leak, help find where its from! (xerox445)
yep. when you pull the tranny off, then remove the clutch and flywheel. you'll see a brown(if oem) round seal connected to your block, which is installed in a plate. just remove the 10 mm bolts holding it. you'll need to press out the seal.
Re: Oil leak, help find where its from! (Djaric)
i already did the valve cover, that was easy...
I heard you can just cut it out with an exacto knife??? and tap the other one in with a rubber mallet?
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 »</TD></TR><TR><TD CLASS="quote">i already did the valve cover, that was easy...
I heard you can just cut it out with an exacto knife??? and tap the other one in with a rubber mallet?</TD></TR></TABLE>
You are correct.
You are correct.
Take a small to medium wood screw, screw it half way into the seal or at least enough to get a good hold, and pry it out. Thats how we do it at work.
beanbag
12-29-2007 12:16 AM
