broke my tps on my 2k si throttle body would an ls one fit?
i broke my tps on my throttlwe body puittin my motor in a truck because it was suspose to go in my car today but nope i need to find a throttle body for it now what throttle bodys yould fit my 2000 civic si?
1 Post
Re: broke my tps on my 2k si throttle body would an ls one fit? (Turbo D' Sol)
you can change the TPS-no need to replace the throttle body.you can use one off any sidedraft honda.the only ones you can't use are the downdraft style(cars with the TB facing upward)-they rotate the wrong way(from DPFI EFs,and i beleive the EK downdraft cars also turn the wrong way).
chris
chris
Re: broke my tps on my 2k si throttle body would an ls one fit? (b20vtec ef8)
Isn't the tps like wound up inside and thats why Honda doesn't put normal bolts on them so you can remove them? I remember switching a couple TPS sensors and after that there were some idling problems.
1 Post
Re: broke my tps on my 2k si throttle body would an ls one fit? (boostsohfast)
the TPS is a simple potentiometer.it has a keyway that locks into the throttle plate. you just have to adjust it once it's installed.
chris
chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec ef8 »</TD></TR><TR><TD CLASS="quote">I would go a typical Tape R manifold but that is just me</TD></TR></TABLE>
How does this relate to his question? Not at all! Don't replace the TB, just get a new tps!
ek_99_SiR
07-19-2005 09:34 PM
