What type of paint/enamel to use on the inside of an oilpan?
I just got this oil pan. It was tapped, and so some paint needed to be sanded off to weld.
Any Ideas on what to use?
Thanks
Thanks
Re: What type of paint/enamel to use on the inside of an oilpan? (sheissrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheissrx »</TD></TR><TR><TD CLASS="quote">I just got this oil pan. It was tapped, and so some paint needed to be sanded off to weld.
Thanks</TD></TR></TABLE>
I am not quite following you but WHY would you want to paint the inside of your oil pan????
Re: What type of paint/enamel to use on the inside of an oilpan? (specv5150)
because
1) rust will mix with the oil,
2) i dont know how the oil will react chemically with whatever metal they use for the pan. It comes fully painted from the factory for a reason.
the inside of the pan doesn't relly need to be painted,,,,, there's oil inside kinda imposible for it to rust from the inside
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: What type of paint/enamel to use on the inside of an oilpan? (ReDHaTcHy97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 »</TD></TR><TR><TD CLASS="quote">the inside of the pan doesn't relly need to be painted,,,,, there's oil inside kinda imposible for it to rust from the inside </TD></TR></TABLE>
this is a extremely sarcastic suggestion.do NOT use enamel...use OIL BAsed paint!your dumb
1 Post
Re: (narib2oo1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 »</TD></TR><TR><TD CLASS="quote">mix the paint with the engine oil before you start the car up...it will work its way down </TD></TR></TABLE>
this also helps coat internal engine parts like rods, you don;t want those rusting away now do you?
1 Post
Re: (sheissrx)
[QUOTE=sheissrx]I think he was being sarcastic....[/QUOTE
good catch danno... in all seriousness, just hit the outside with a little black rustoleum, and you will be good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheissrx »</TD></TR><TR><TD CLASS="quote">because
2) i dont know how the oil will react chemically with whatever metal they use for the pan. It comes fully painted from the factory for a reason.</TD></TR></TABLE>
Sorry it is impossible for something with oil in contact with it for it to actualy rust. If it were to rust there would be a bigger problem than rust like water in your oil.
Hondaciv866
07-22-2012 08:57 AM
Oil Pan baffle welded in. What to spray the inside pan with? To prevent rust, etc. Similiar to OEM p
AspectIndustries
04-20-2006 01:26 PM
E-AT_me
01-24-2006 05:40 AM
