whats this plug for
whats this plug for
After i replaced my heater core (which kinda sucked) in my 95 civic i have this mystery plug hanging by the diagnostic plug. It has 3 wires coming from it which are light blue, black w/red stripe, white w/red stripe. Does anybody know what this is for?
My father disassembled the passenger side while i did the drivers side, but i had to put it all back together.
Re: whats this plug for (zman)
diagnosis of engine codes... check the ECU Code sticky it shows you have to use it nice and good (sticky = always at the top of page 1 in this forum)
Re: whats this plug for (slowdx9585)
no he is talking about the other, i think it wont be plugeed into anything cause when i was searching for my service jack i found the same thing
i'm sorry, but did you even read my post? I said its the plug hanging beside my diagnostic plug. Can't you see the diagnostic plug hanging in the picture? (its the one that i am NOT holding).
I am asking about the plug that i am holding in the picture.
i'm thinking that it's an aldl (assembly line diagnostic link) but yeah i couldn't figure out what it's for either i know it doesn't get plugged in to any thing.
Re: whats this plug for (baseballinmyass)
ok thanks, that clears things up.
I was also wondering, after i finished putting the dash back together and put back in i couldn't find the plug for the power mirror switch. Do you know what color plug it is? The plugs for the moonroof, cruise control and dimmer switch all are different colors.
I can't seem to find the plug for the power mirrors, anybody know where it might be?
Well, you can also read the post by slowdx9585 a little less harsch and USE the service connector to see if any blinking code appears. If the connector is imporant, there should be a blinking code.
Good luck.
Good luck.
Niskyspy
13
03-10-2008 05:54 PM
