*HELP* Power steering removal! *HELP*
Guys, I know this has been covered before, but search is down, and I need to get this done ASAP. I have a mad leak in my p/s (i.e. the contents of the reservoir are leaked out as soon as I turn the car on) and I'm going to remove it until I can go buy the replacement hose and line (if I decide to put it back on).
TIA, guys.
Edit: I'm not removing it for power, I'm removing it so I don't burn out the pump due to a lack of fluid.
TIA, guys.
Re: *HELP* Power steering removal! *HELP* (jeef84)
remove the belt and the pump will no longer run... That's it.
Fix your problem, the reinstall belt so your system works again.
There's no tensioner. There's some bolts that hold the powersteering pump (I think 2 12mm). Loosen them a little and then you should be able to slide the pump towards the firewall and then you can just pull the belt out of the way.
MiKeAhOwSkI
11
07-29-2004 07:21 AM
