sticky temperature control switch
The temp control switch on my EG gets stuck and takes a lot of effort to slide from cold to hot. I've located the moving parts under the dash but I'm unable to determine which component it is that is causing the problem. Also, it doesn't look like it rotates on a hinge or anything that could simply be re-lubricated. Does anyone have a solution or should I just start taking stuff apart?
