"Gas Gauge Doesn't Work" needle stays above F
after removing indiglow gauges CAREFULLY my gas gauge doesn't work. the needle stays at above full. what can i do to fix this? everything else works perfect. thanks!
Re: "Gas Gauge Doesn't Work" needle stays above F (slammedef06)
You'll need to replace it. If you have an EK, you can get a new fuel guage from http://www.slhondaparts.com; I'm not sure if you can do that with an EG. Otherwise, you can swap the whole cluster.
Re: "Gas Gauge Doesn't Work" needle stays above F (Ricey McRicerton)
thanks for the help! Actually i didn't pull the needles off i worked around them but i must have hit the gas needle by mistake. i guess i'll have to buy a whole new cluster.
You can actually just buy the fuel guage (or the fuel/temp gauge depending on what guages you have in there).
for future reference.. If removed them becuase you didnt like them and you were gonna throw them away you shoudl have just cut them off...
Hiroshima_VTi-S
05-30-2007 10:35 PM
