B&M FPR Problem
B&M FPR Problem
I have a 94 EG with a B16 in it, I have an AEM high flow fuel rail with stock injectors. My problem is that when ever I try to set the pressure with just the fuel pump primed, as soon as I start the car it jumps up. Ill set the pressure at 38PSI and as soon as it is started it will jump to 42PSI. is there something im doing wrong? is the FPR shot?
D Tranny Guru
yep!!!!!!!!!
Lucky yours is only stuck part open. If it stick wide open, all the fuel is bypassed back to the tank, interior will reek of gas, car losses about 90% of it power.
I got stranded in a hotel parking lot, 2 days before a import race. If this would have happened while running the 85 ZEX shot, motor would had died, explosively!!!!!
When I put the motor in at the beginning of summer after installing the fpr and a bunch of other stuff, it was real sluggish and it drank gas like crazy. Should I buy an aem fpr?
Thanks for the help.
Eric
Eric
Re: (fasthatchb18c1)
I think they were implyin that they are known to stick..not all of them will stick...just his is partially stuck...I had one for 1 yr..and was fine.. then i switched setups all together..
dunkd
04-06-2006 07:47 PM
