Civic Winter Storage Prep?
I own a 1995 Honda Civic DX Hatchback, I live in Wisconsin, We have very harsh Winters, my hatch is dumped wayyyy to low to drive in snow. I'm going to rent a spot in a garage to keep it out of the snow, but the car will not be driven/started all winter. I have a D16 out of a 2000 DX if that changes anything. I am wondering what I should do before the car get shut down for winter, this will be my 2nd time storing a car, last time the radiator cracked over the winter, and the tires all cracked and went flat (91 Eclipse), but I did nothing before I stored it. With this car it will be in a Garage instead of outside, and I plan on putting it up on jackstands w/o wheels to help save the tires, is this a good or bad idea?
Thanks in advanced
Thanks in advanced
Re: Civic Winter Storage Prep? (SonicEG)
I would like to know as well, not for cold weather but if I have to leave it what should I put in the gas tank to keep the gas alright? I have heard stabil, then I heard seafoam
Not sure about what else to do as I have never had to do it, but putting the car on jackstands is a good idea.
If anything, I would just go and started up and let it run for a bit every few weeks or so, while on jackstands.
Re: Civic Winter Storage Prep? (dmxsoulja3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 »</TD></TR><TR><TD CLASS="quote">I would like to know as well, not for cold weather but if I have to leave it what should I put in the gas tank to keep the gas alright? I have heard stabil, then I heard seafoam</TD></TR></TABLE>
Seafoam or drain the gas, drain the radiator and block and fill with 100% antifreeze. The more water the more likely you are to freeze it and crack the rad. Jack stands a good idea for the tires. Clean the paint job finish and put a fresh coat of wax. I would change oil before starting it back up.
Re: (4door_demon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon »</TD></TR><TR><TD CLASS="quote">Not sure about what else to do as I have never had to do it, but putting the car on jackstands is a good idea.
If anything, I would just go and started up and let it run for a bit every few weeks or so, while on jackstands.</TD></TR></TABLE>
Afaik, letting it run for a bit may not let the engine heat up, and your engine will layer sludge on the valves or in the catalytic converter every few weeks or so. I would leave it off or do at least 50 miles every sunday afternoon.
Re: (f1z1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c »</TD></TR><TR><TD CLASS="quote">
Well, I did mean to run it until it reaches operating temp, but if he does have the ability to take it out for a run every so often, then that would be better.
I dont want to drive it at all in this area during the winter, the roads blow. I think I heard bad things about running pure antifreeze? Or was it pure water? Not just during storage/cold or w/e, just in general. Either way, fresh coolant, seafoam the gas, jack stands, and fresh oil before startup? What about my suspension, is it gonna get fucked up from being up on jacks so long and the suspension hanging down? Thanks
civicbutter
01-28-2013 11:01 AM
ataplin777
07-31-2011 01:50 PM
